Application too display cell info etc etc on samsung phone
  • ^^TommyTee
    • 424
    hi
    do you folks know of any application that will run on a samsung phone which will give me the cell info and such jibber jabber ?
    any info appreciated
    regards
    Please be aware all my posts and associated links are purley for educational purposes only ... i will not be held responsable if you use any of this material or links whatsoever its at your own risk!!
    I do not condone any illeigal use of any information contained within.
    No1 Automotive Contributor ? BOLLOX
    PEOPLE CALL YOU A TWAT !!!
    Greetingz too 0ptik and the TRUE
    Automotive RSE Crew
  • thewizardofodds
    • 924
    Used to just use keypad codes back in the day for this kind of thing so possibly still the same.
    found these
    Samsung Cell Phones - Programmer Codes
    11 Apr 2007 | Sent in by GodCube
    Type these codes into the phone where you normally would make a call.
    #646# then press the Call button: T-Mobile Customers only, shows minute usage.
    *#06# : Show IMEI
    *#9999# : Show Software Version
    *#0837# : Show Software Version (instructions)
    *#0001# : Show Serial Parameters
    *#9125# : Activates the smiley when charging.
    *#9998*228# : Battery status (capacity, voltage, temperature)
    *#9998*246# : Program status
    *#9998*289# : Change Alarm Buzzer Frequency
    *#9998*324# : Debug screens
    *#9998*364# : Watchdog
    *#9998*377# : EEPROM Error Stack - Use side keys to select values. Cancel and ok.
    *#9998*427# : Trace Watchdog
    *#9998*523# : Change LCD contrast - Only with version G60RL01W
    *#9998*544# : Jig detect
    *#9998*636# : Memory status
    *#9998*746# : SIM File Size
    *#9998*778# : SIM Service Table
    *#9998*785# : RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error.
    *#9998*786# : Run, Last UP, Last DOWN
    *#9998*837# : Software Version
    *#9998*842# : Test Vibrator - Flash the screenligth during 10 seconds and vibration activated.
    *#9998*862# : Vocoder Reg - Normal, Earphone or carkit can be selected
    *#9998*872# : Diag
    *#9998*947# : Reset On Fatal Error
    *#9998*999# : Last/Chk
    *#9998*9266# : Yann debug screen (=Debug Screens?)
    *#9998*9999# : Software version
    If the Codes above dont work, you should change *#9998* to *#0. i.e. *#9998*523# change to *#0523#. Another thing that will help is to remove your SIM card.
    *0001*s*f*t# : Changes serial parameters (s=?, f=0,1, t=0,1)
    *0002*?# : unknown
    *0003*?# : unknown
    SP-unlock SGH-600 (and also SGH-2100)
    *2767*3855# : Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!! )
    But also changes IMEI to 447967-89-400044-0. (Doing this is illegal)
    *2767*2878# : Custom EEEPROM Reset
    *#06# displays phones IMEI NO.
    *#9999# SW Version.
    *#8888# HW Version.
    *#0842# Vibrator.
    *#0289# Buzzer.
    *#0228# Battery Stat.
    *#0782# RTC Display (??)
    *#0523# LCD Contrast.
    *#0377# NVM error log (??)
    *#5646# GSM Logo Set.
    *#0778# Sim Serv, Table. (??)
    *#0638# SIM Network ID.
    *#0746# SIM info.
    *#0076# Production No.
    *#3323# Forced Crash (?? don't know, but does not sound good)
    *#2576# SIM error.
    *#4357# The actual help screen
    *#9324# Netmon <> press the hang up key to exit.
    *#0778# To see what your SIM suportes.
    *#0746# Your sim type.
    *#32439483 Digital Audio Interference off.
    *#32436837# Digital Audio Interference on.
    *#9998*9999# Sotfware Version.
    *#9998*8888# Hardware Version.
    *#9998*377# Non Volatile Merory Error Log.
    *#9998*778# SIM Serv. Table.
    *#9998*968# Remider Tune.
    *#9998*2576# Forces SIM Error.
    *#9998*533# (LED).
    *#999* Show date and alarm clock.
    *#8999*638# show network information.
    *#9998*5646# change operator logoat startup.
    *#9998*968# View melody alarm.
    #0111*0000000# Removes SIM Lock.
    *2767*688# = Unlocking code
    *#8999*8378# = All in one code
    *#4777*8665# = GPSR Tool
    *#8999*3825583# = External Display
    *#8999*377# = Errors
    *#2255# = call list
    #*5737425# = JAVA Something chouse 2and it chrashed.
    #*536961# = Java Status Code
    #*536962# = Java Status Code
    #*536963# = Java Status Code
    #*53696# = Java Status Code
    #*1200# = AFC DAC Val
    #*1300# =IMEI
    #*1400# = IMSl
    #*2562# ?? white for 15 sec than restarts.
    #*2565# Check Blocking
    #*3353# check code
    #*3837# = ?? White for 15 secs than restarts.
    #*3849# = ?? white for 15 secs than restarts.
    #*7222# = Operation Typ ( class C GSM)
    #*7224# = I got ERROR !
    #*7252# = Operation Typ ( Class B GPRS)
    #*7271# Multi Slot ( Class 1 GPRS)
    #*7271# Multi Slot ( Class 4 GPRS)
    #*7337# = EEPROM Reset ( unlock and resets Wap settings)
    #*2787# CRTP ON/OFF
    #*3737# L1 Dbg Data
    #*5133# L1 Dbg Data
    #*7288# GPRS Attached
    #*7287# GPRS Detached
    #*7666# SrCell Data
    #*7693# Sleep Act/Deact ( enable or disable the black screen after doing nothen for a while)
    #*7284# Class B/C Or GPRS
    #*2256# Calibration Info
    #*2286# Battery Data
    #*2679# Copycat Feature (Activate or deactavite)
    #*3940# External loop 9600 bps
    #*8462# sleeptime
    #*5176# L1 Sleep
    #*5187# L1C2G Trace ( activate or deactivate)
    #*3877# Dump Of spy trace
    *#8999*636# Have no clue i see 20 lines
    *#8999*8376263# HW Ver SW Ver and build date
    *#746565# Checks the locks
    *7465625*28746# Auto SIM lock On
    #7465625*28746# Auto SIM lock Off
    (*Known Unlock CODES*)
    S500/ P400/ E500/ E700/ X100/ X600/ E100/
    Enter *2767*3855# with and accepted SIM card If this codes fails, Enter *2767*688# or #*
    7337#
    A300/ A400 / A800
    *2767*637#
    Enter code above with an accepted SIM card.
    S100 / S300 / V200 / V205 / E710 / E715 / D410 / X426/
    *2767*7822573738#
    If the code above fails)
    1.) Insert a SIM card which the phone dose not accept.
    2.)If you see wrong Card, type #9998*3323#
    3.)Press exit and select number 7. Phone will reboot.
    4.) Now SIM should work.
    5.) Type *0141# and then press call.
    6.) Power off the phone and inser anther SIM card.
    7.) If a code is requested, enter 00000000.
    These contain text, codes that can be unique for each phone, or some other type of function. I have not tried these.
    *#9998*JAVA# Edit GPRS/CSD settings (S100 only).
    *#9998*Help# Screen / List of codes.
    *#9998*RTC# RTC Display.
    *#9998*bat# Battery Status.
    *#9998*buz# Turns Buzzer On.
    *#9998*vub# Turns Vibator On.
    *#9998*LCD# LCD Contrast.
    *7465625*638*Code# Enables Network lock
    #7465625*638*Code# Disables Network lock
    #7465625*782*code# Disables Subset lock
    *7465625*782*code# Enables subset lock
    *7465625*746*code# Enables SIM lock
    #7465625*746*code# disables SIM lock
    *2767*MEDIA# Resets the media on phone <>DELETES all downloaded PICS/TONES <>
    *2767*FULL# Resets the EEPRON* <>?DANGEROUS?<>
    *2767*CUST# Resets the sustom EEPRON.
    *2767*JAVA# Resets JAV downloads ( dealets all downloaded midits)
    *2767*STACKREST# RESETS STACK.
    *2767*225RESET# ????????????* VERY Dangerous.
    *#9998*NET# SIM NEtwork ID.
    *#9998*NVM# Displays Non-Volitile Mermory Status.
    *#9999*C# Netmon.
    *#9998*DEAD# Forces Phone Crash.
    I have no idea what these do.
    *2767*66335#
    *2767*3700#
    *2767*7100#
    *2767*8200#
    *2767*7300#
    *2767*2877368#
    *2767*33927#
    *2767*85927#
    *2767*48927#
    *2767*37927#
    *2767*28927#
    *2767*65927#
    *2767*29927#
    *2767*78927#
    *2767*77927#
    *2767*79928#
    *2767*82927#
    *2767*787927#
    *2767*73738927#
    *2767*33667#
    *2767*85667#
    • ^^TommyTee
      • 424
      cheers pal
      keep up the good work
      Automotive RSE Crew
      • thewizardofodds
        • 924
        tried on my basic samsung and some still work
        • Jim.Mahoney
          • Feb 2010
          • 4249
          Just a word of warning on Samsung codes especially those beginning with a 7! These can render many newer Samsung models to their pre-programmed factory state and apart from losing anything important on your handset, you could end up with a IMEI of fifteen zeros!!
          • thewizardofodds
            • 924
            and does an imei with 15 zeros work in uk?
            • Canker_Canison
              • 3905
              Nope.
              The IMEI would need rebuilding. But not all models can be done.
              Canker
              [COLOR=Green]
