IMEI Number
  • yaas
    • Jun 2009
    • 188
    IMEI Number
    Hi!
    Does anyone know how I can get the IMEI number for a HUAWEI E156G?
    Thanks.
  • jonesy118
    • Mar 2010
    • 28
    do you simply just mean how to find out what the IMEI of your phone is?
    look on the box, on the phone under the battery, or type *#06# on the phone and it sould bring it up on screen.
    • Jim.Mahoney
      • Feb 2010
      • 4249
      Originally posted by yaas
      Hi!
      Thanks.
      It's a modem and so *#06# can not be used! It has no battery to look under, no keypad and no screen!
      It is usually on the body of the device, 15 digits long.
      If it can not be found the use your dashboard software, it'll be under diagnostics, device info or something similar. Without know what dashboard you're using I can only be vague but you'll find it eventually!!
      • jonesy118
        • Mar 2010
        • 28
        sorry, my bad!
        • Jim.Mahoney
          • Feb 2010
          • 4249
          Originally posted by jonesy118
          sorry, my bad!
          In the corner with you for 5 minutes!
          • yaas
            • Jun 2009
            • 188
            Its not mine.
            I am just trying to unlock it for a friend.
            I am on Windows 7.
            Hope somebody can help.
            • Jim.Mahoney
              • Feb 2010
              • 4249
              Its not mine.
              I am on Windows 7.
              If it can not be found on the body of the modem then use the dashboard software, it'll be under diagnostics, device info or something similar. Without knowing what dashboard you're using I can only be vague but you'll find it eventually!!
              • yaas
                • Jun 2009
                • 188
                See, I am really new to this & I doubt it very much if I'll find it.
                For a start, I don't even know what you mean when you say "dashboard"!!!
                Sorry!
                • tshirtman
                  • 1345
                  follow link, and in step by step guide, check the first and last guide
                  Help & Support
                  !retupmoc eht ni deppart m'I !pleH
                  • Jim.Mahoney
                    • Feb 2010
                    • 4249
                    Help & Support
                    Three UK use their own dashboard as do Vodafone but the principle is much the same!
                    • tshirtman
                      • 1345
                      ye your right mate, I don't know why I presumed it was the three network, I personally use vodafone dongle, and it is basically the same,
                      your dongle will automatically install the software on first use, then it's easy to get to the dashboard from there
                      • Canker_Canison
                        • 3904
                        Just to make sure you understand....
                        The 'dashboard' is the software the dongle installs to the PC. It can also be refered to as the 'User Interface' or just 'software'
                        Canker
                        [COLOR=Green]
                        • yaas
                          • Jun 2009
                          • 188
                          You guys are all being really helpful but I am still stuck without IMEI number.
                          The dongle is not mine.
                          I want to get the IMEI number by just plugging it to my pc.
                          Is there a way to do it that way?
                          • Jim.Mahoney
                            • Feb 2010
                            • 4249
                            Yes, just plug the dongle in and it'll install everything for you. Once you've got the IMEI you can un-install via Windows Control Panel.
                            Install takes around 10 minutes or so...
                            • yaas
                              • Jun 2009
                              • 188
                              I plugged it in but nothing happens.
                              What should I do?
