battery life on zte blade
  • bandit boy
    • 155
    This phone is 2 months old now great phone but the battery life is very poor only lasting a day max even if i dont make a call just left in stand bye any idea on how i can increase the battery life .thanks
  • Shady
    Shite Link King
    • Dec 2010
    • 6404
    Turn off Bluetooth, sat navigation. Wifi when not in use
    Sent from my ZTE-RACER using Tapatalk
    • bandit boy
      • 155
      i have tryed all that m8
      • zaphodbb
        DK Daddy PT
        • 1083
        i had same problem but i use advanced task killer and kill all apps except emails and sms battery still not great though but better !!
        • Canker_Canison
          • 3905
          Also turn off the 3G connection (found in 'Network' menu). You will only need the 3G turning on when you're going on-line. 3G kills every phones battery life.
          Canker
          [COLOR=Green]
          • zander1
            • 28
            Hi Bandit boy you can recalibrate the the battery if you have the phone rooted . I now get three days without a charge depending on my usage just follow these instructions.
            1.Connect the phone to the charger with the phone powered on, and allow the phone to charge until the notification LED is green, indicating the device is fully charged.
            2.Disconnect the phone from the charger, and power it off.
            3.Reconnect the phone to the charger with the phone powered off, and allow the phone to charge until the notification LED is green.
            4.Disconnect the phone from the charger and power it on.
            5.Once the phone is powered completely on, power it off again and reconnect it to the charger until the notification LED is green.
            6.Disconnect the phone, power it on in clockwork recovery, and wipe batt stats. You need to use this sequence only once.
            Because we are using the Blade ignore the "green LED" because Blade goes green at 90%. Just charge it for a while, max it out each time.
            By the way this is not my work found it on another site .
