ET9000HD Discussion
  • aftermath
    • 4345
    ET9000HD Discussion
    Please Post any Clarke Tech ET9000 Discussions in Here.
  • Im85288
    • Aug 2011
    • 68
    Problems with ViX skin on 2.2.1
    Has anyone had any performance problems using the ViX skin on version 2.2.1 of the ViX image? For a couple of months I noticed bad slowdown where the receiver would not respond for up to 10 seconds at a time. I changed the skin to use Magic HD and since then have not had any problems at all. Hope this is helpful for someone
    • RuberDuck
      • 1724
      i have never heard of a single person having slowdown issues using the ViX skin, have you got picons or a EPG set up and if yes how are they set up and where do they save to ? for example internal flash or a USB stick ?.
      • Im85288
        • Aug 2011
        • 68
        It is very strange I agree, but indeed that is what happened on my setup. I do have both the EPG and Picons setup saved to a USB stick. Using CrossEPG it retrieves data for approx 5 different satellites including 28.2e
        • RuberDuck
          • 1724
          thats the problem, your asking way too much of crossepg in a single go.
          • Im85288
            • Aug 2011
            • 68
            Thanks for the tip, I'll try to reduce the number of feeds crossepg accesses and see if that makes a difference when using the vix skin.
            • RuberDuck
              • 1724
              it has nothing at all to do with the skin it's just crossepg can be a little hungry when using too many sources.
              • Gokhle
                • Apr 2011
                someone tell which images best for ET9000HD
                • afc007
                  • Mar 2010
                  • 55
                  there are plenty to choose from and now most images are very much the same in what they offer or can do
                  however i would recommend either an open pli or any of the many oe2 Alliance available.
                  xtrend ET 9000 HD , ipbox 9000 HD & 1mtr Dish
