Hi just got my et9200 today and i added my n line to the cccam.cfg which is in the /etc/ folder, i have tried restarting the box to no avail please help thank you.
et9200 cccam.cfg help
Tags: None
its all plugged up correctly but on the box says not connected to the Internet? also the et9200 menu is a bit to the left so i cant read it clearly a few letters are missing as i cant see them any idea there also thanksComment
Sorted the problem now, anyone no how to sort the picture ratio out as i cant see the left hand side of the menu a few letters are missing and needs to be moved overComment
depends on which image you are using i know Vix have a sub menu on there image to correct any overscan problems, But generally if you using on an lcd or plasma then setting the A/V settings to just scale should sort it.
using vix on et9200 for 4 months now and is fraultless, if you have image out on the left, to me sounds like your tv as i never had to set that at all on my boxMY POSTS AND ANY PM`S ARE PURELY FOR EDUCATIONAL AND LEARNING PURPOSES
I AM FULLY RESPONSIBLE FOR MY OWN POSTS, MY POSTS ARE NOT CONDONED, MODERATED OR AUTHORISED BY ANY MEMBER OF STAFF ON THIS SITE AND I TAKE FULL RESPONSIBILITY FOR ANY CONTENT CONTAINED IN MY POSTS OR LINKED TO EXTERNALLY.Comment
