Xtrend ET-9200 - Tuner failed!
  • satlover276
    • Oct 2011
    • 95
    Hi, I would be very grateful for your help regarding a problem with my Xtrend 9200 receiver.
    Since last week, upon startup, i am unable to receive any channels. I have a 'Tune failed!' message appear
    on screen. After switching off then on again i get the same problem so i am unable to receive any channels.
    The same problem exists after i flash different images.
    On a couple of occasions having left the receiver on a channel where the Tuner A indicator appears in green (not yellow)
    i have found after many hours that the channel is received. Unfortunately once i switch the receiver to standby or sometimes
    change channel i get the 'Tuner failed!' message again. This problem continues and i cannot receive any channels now.
    I read there is an address somewhere in Germany where i can send the receiver to be fixed. Does anybody know is this is correct and what the address is please?
    Many thanks if you can help me.
  • digicon
    • 8261
    I would not bother sending it to Germany i had an old ET9000 model same as the 9200 apart from cosmetic differences, They basically sent it back as parts are no longer available.
    Time to move onto a different receiver
    • satlover276
      • Oct 2011
      • 95
      Okay i understand.
      • tango01
        • 18
        Hi There
        I actually had this also.
        I basically in the end factory reset it and started again and it worked
        • EdmondGo
          • Oct 2019
          Definitely, reset it to factory settings helps in this case.
          • scottroberts
            • Aug 2020
            It's a rather old and cheap tuner. I would just ditch it and buy a better one!
