humax foxsat extra sats
  • edward hitler
    • 50
    Recently found out that my freesat box has a hidden menu that allows me to change the set up of the dish to a motorized dish and it has a list of satellites. If I got a motorized dish what channels would be freely available? It's a humax foxsat freesat hd reciever.
  • billy2
    • 1381
    yep it has
    To access the hidden menu for diseqc settings and usals
    Press
    Menu
    Setup
    Freesat tune then press
    Red Button
    Green Button
    Yellow Button
    Blue Button
    Green Button
    Yellow Button
    Blue Button
    Then the Antenna settings option should appear.
    and then you can access the Antenna Settings part of the menu. to set up your diseqc.
    you can pick up all free to air channles and they can be found here
    KingOfSat - European Satellite Zapping & Directory
    please press the little red THANKS tab
    if I helped if not press the green tab to tell me to f**Koff
    • dctyper
      • 2539
      how far can this box be used? ie patched or cs?
      Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
      previous life dm800hd and 500c on cable screw you nag3
      • Sicilian
        • 168
        This is a non linux box so pretty sure cccam cannot be used, i'm also pretty sure the ethernet port is disabled on these boxes, so that counts out cs.
        D I S C L A I M E R My right to post information is protected under the rights for freedom act. In all instances, information discussed here on my posts are either hypothetical in nature, out of general curiosity, common knowledge, public knowledge, or role-play. Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader. I am not responsible for what you do with it.
