sky dish
  • handyguy2002
    • 95
    sky dish
    hi guys
    ive been useing a sky dish pointing at 13e working fine,
    now then I want to conect a duel LMB from maplins to the dish, would this work with the sky dish as I asked in the shop and they said that it wont work
    I was thinking about making the dish motorized but dont think it would worth it for just 19e and 13e
  • mdt
    • 3034
    Originally posted by handyguy2002
    hi guys
    if you have a zone1 45cm mini-dish then it wont work but if you have a zone2 65cm dish, or an old 60cm "s*y analogue" dish., depending on your location then you could use the mono-block pictured for reception of 19.2e and 13e using 13e as the primary focus. zone1 "s*y mini-dishes" are really only any good for the very powerfull birds at 28.2/28.5 east although ive seen one thats used for the french terrestrial channels at 5w without any problems. regards mdt p.s. there are cheaper places than maplin for lnb,s ect.
    • handyguy2002
      • 95
      hi there
      I think its the 45cm as its not as big as my new sly dish,
      would I have to buy a holder too use the mono block or would it fit onto the holder that is in the dish already
      • mdt
        • 3034
        hi there
        you have a new s*y dish thats bigger than a zone 1?? please explain what system you have, how many dishes, what size, fixed or motorised, which satellites they are recieving, how many recievers. regards mdt
        • handyguy2002
          • 95
          hi
          I have sky dish with 6 or 8 multi outputs that supplys feeds to
          sly hd + box
          and another 4 sly box's for kids
          which I dont wanna move as its ok for kids
          I got given another sly dish with a 4way lmb so got it pointing at 13e but wanting to use 19e too
          using openbox s9 hd box which does the job
          also have a itgate 220 c@ble but im looking for a sat tuner
          so I can use it in another room
          also have a manhattan plazza 300 that i understand cant be used other than fta
          and a tevion that I was using for camping untill I put wrong software on, so needs jtaging when find out how
          the wife not happy with anything that is out of place, a eye sore ,
          thats why I was asking the above as she seems happy with that dish
          • mdt
            • 3034
            hi
            sly hd + box
            if your other s*y dish is the 45cm zone 1 type then its to small for a mono-block (its not really big enough for hotbird either) but if its a 65cm zone 2 dish then you can get a 6 degree mono-block and swap the lnb over but you might need a lnb adapter if the lnb and bracket are 1 piece. regards mdt
            • handyguy2002
              • 95
              ok thank you
