Spiderbox-USB
  • Franktheplank
    • Feb 2011
    • 27
    Spiderbox-USB
    Hi all I have a 1gb USB with gift etc on it in usb1 & a 1tb in USB 2 when I try to record, it records on the 1gb but because it has patch gift etc on it & not enough memory it stops after about 20 mins. If I switch to the 2nd USB the gift is turned off there for I'm unable to record as their is no channels. So will I have to connect 1gb to comp & drag it in to a file & also connect 1tb then drag it over?? Will I lose any data or is their a download i need to perfom or something On the box I can do to transfer it all to the 1tb which is format32 not nfts???
  • Manic01
    • 5117
    The gift is not on the usb stick Frank.
    Just use the big hdd and you need to format to fat 32 first.
    Save progs and channel lists to that drive.
    • setfiretorain
      • Jul 2010
      • 934
      Mate, you update the box firmware, then that USB is no longer needed to be plugged in so you can remove it, then format the 1tb to Fat 32, You then plug that in and you can record etc!
      Regards, Ellis.
      Sat Boxes
      Dreambox 500s.
      Dishes
      Sky minidish self fitted.
