how do I add more sattelites on my spiderbox9000hd...have 10 on it at the moment,,,thanks
adding sats on spiderbox
if you mean adding sats that are already in the database go to installation>motor setup>motor type=usals>satellite>ok select sat wanted>ok>search option=you choose then start search>ok. or put a pre-configured channel list in check your long/lat settings after though.Comment
If you mean transponders, You go to manual scan, Go to the satellite desired, and press the green button, Then add a transponder and scan for it.
Regards, Ellis.
Sat Boxes
Dreambox 500s.
Dishes
Sky minidish self fitted.Comment
