help not getting Pick tv channels
  • chazt
    • 166
    not getting pick tv channels today was ok yesterday central scotland here anyone any ideas
  • psul
    • 24
    from what I've read elsewhere seems sky are testing anti cs measures similar to what they did with sky Italy a while back.
    Seems all emus are affected except oscam.
    • chazt
      • 166
      can you explain, more kinda new at this ie emus and oscam thanks
      • ohno
        • 134
        cant clear it here with cccam!!!
        ive a bad feeling this is going to become the most viewed thread with maybe namechange(i hope not) algo has changed on this channel today,
        • painterman
          • 28
          Channel will clear fine using CCcam + Oscam_r4396, however card will need updating in original box when entitlements run near end.
          • chazt
            • 166
            thanks for this
            can you tell me how to do this on pli jade3 maxvar
            new at this
            • painterman
              • 28
              This is not gonna be easy for newbie user who does not understand Oscam.
              I can tell you about it on EDG Nemesis (800HD )2.2 image it is BLUE button > ADD ONS MANAGER > DOWNLOAD EXTRA > e2Cardserver > Oscam r4396 Wi > download install > back to BLUE button menu > Cardservers >select Oscam run it (make sure in Softcams (CCcam) is set to NONE 1st) >Select Softcam (use any that you currently use ,CCcam 2.1.3,CCcam 2.2.1). Oscam + CCcam should start now.
              You need to have Oscam config files & need to update change them to suit 0963 card.
              I used Download Extra (BLUE BUTTON ) to get e2Config > downloaded Oscam 0919 1 slot > use any program like Flash FXP or DCC296 > enter VAR > TUXBOX > Config > change/edit files OSCAM CONF > OSCAM SERVER > OSCAM USER > you enter oscam settings for 0963 card now,change ports,add users etc.
              You could find program like Oscam Config CREATOR V3.0 & learn to use that that comes with lot of support for many cards ,how ever there is lot of learning to do for novice users.
              • davvo
                • Apr 2009
                • 666
                pick tv and pick tv+1 are on the same
                transponders as sky sports 1234 and sky 1 and 2
                so maybe they test on picktv
                when the time is right bang goes sky sports
                and who knows what next
                if they do that cccam is dead for sly anyway
                unless someone updates cccam
                • davvo
                  • Apr 2009
                  • 666
                  • belfastdaren
                    • Oct 2008
                    • 356
                    working
                    look for bbc tes 3 this is pick tv
                    • joe516
                      • 1000
                      cbbc 4 me m8
                      • davvo
                        • Apr 2009
                        • 666
                        its cbbc its a fta bcc channel
                        • kopkidda
                          • 122
                          ok thanks davvo
                          • davvo
                            • Apr 2009
                            • 666
                            ,,,,,,,,,,,ok
                            • belfastdaren
                              • Oct 2008
                              • 356
                              pick tv dosent stat to later in day ccbc channel during the day
