Monoblock LNB Help Needed
  • RobertArm strong78
    • Feb 2011
    • 18
    HI All,
    I have a 6 Degree Monoblock meant for 13e & 19.2e
    Is it possible to put the left hand horn into the holder and get 13e & 7e ?
    Do i leave my dish on 13e ?
    Do i need to put the 7e horn lower as opposed to higher with 19.2 ?
    Rob
  • dick b
    • Jun 2009
    • 2462
    try it but as 7E will not be as strong(although most of the FTA channels are pretty good) as 13E use that as the prime sat.with the 13E horn to the right of it when viewed from behind the dish.which should be slightly higher than the 7E one as everything is reversed,
    M6-suisse on 11.283 V 27500 is a good channel on 7E to set up on.
    as your dish is already set on 13E I"d try that 1st,the 7E horn then wants to be to the left of it when viewed from behind the dish and slightly lower but trial and error will find it.so from your present set up switch the horns over then in the stb change the diseqc switch to get 13E back and the other switch position will be used for 7E.otherwise start from scratch as above.
      • Feb 2011
      • 18
      great, thanks for your time , i will try that this evening !
      • dick b
        • Jun 2009
        • 2462
        hope this helps
