Hi all,please be patient with me as i have not got very good satellite knowledge but basically i got sky turned of,got myself a 90cm fortec star dish,technomate 5400,and tring card.having put my dish up i cant seem to find eutelsat w2 16e so i called out the local satman and he couldnt find it either.im using my sky lnb,could someone please help.i bought the dish on the recommendation of 3 sat installers.i live in co down, n.ireland.many thanks,,,
EUTELSAT W2 16E PROBLEM
16e is weak and sits between 13e and 19.2e so it tends to get overshadowed by them when you search for it. You will keep getting their signal instead.
If you can get the use of a decent meter, search for 11283H, the Tring transponder.Get to the Ulster Grand Prix
Dundrod Co. Antrim
Every August
Learn what fast Really is!
NOT for the faint hearted
or watch it on BBC NI HD the following week
(What is football all about?)
change your lnb also as the sly lnb,s have a oval feedhorn designed for the mini-dish as you will be losing some signal there also. regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
use Satellite Finder / Dish Pointing Calculator with Google Maps | DishPointer.com that will give you the direction to start off for 16E and will also give the skew(twist) of the LNB needed for a fixed dish just enter your address and you will find you can move the pointer to your exact house.Comment
are you getting bbc world on 1 west if you are getting a good signal there are your coordinates for your location entered into the box correctly it should track through the satellites if you use usals and you have a good signal on 1 westComment
I think he is on a fixed dish.Comment
.let you know what happens,but either way il be back 2 test your patience in the future..many thanks,,,
