which set up
  • swifty
    • 63
    which set up
    which set up would i need i only really wanna watch sly sports an movies an espn not to bothered bout anythin else an wot wud it cost. any help would be much appreciated thanks loads
  • benny/9
    • 1964
    the easiest way is the protek hd box it's more or less
    plug and play it updates it's self etc: but if you dont have
    a dish set up you will need a full system and to get the best
    from any sat box you need a motorised system and i would
    say get a 1 mtr dish. as for cost i dont know but others will
    have that info and you could try a google for this setup and cost.
    Please Read Carefully!
    • MrFug
      • 880
      If Sly Sports and EPSN is all you want, then a fixed dish at 28.2 is all you NEED. As Benny said a motorised system really gets the most from Satellite. Getting this installed professionally could cost you in the region of ?400 though.
      I'd learn about doing it yourself, you can get a full motorised package (minus receiver) for ?100-130 on ebay.
      Another good choice would be a fixed dish with multiple LNB's. I recently saw a full package (80cm dish, x3 lnbs, diseqc switch, wall mount, coaxial cable) for under ?70 on Ebay. This would get you 28.2 (Sly UK), 19.2, and 13e (LOTS of european channels). One advantage of this setup is fast channel switching (you don't have to wait for a motor to turn).
      OR simply pick up a Sky mini-dish pack on eBay for ?30ish.
      Get a linux satellite box to make the most of it. Clone Dreambox 500s are around ?50. HD DM800's are about ?160.
      Hope this helps
      • swifty
        • 63
        i think i will fit a motorised dish so i dont need 2 upgrade later if i do also can i use the cable my sky dish was connected to many thanks
        • MrFug
          • 880
          Your sky cable should be fine. Although if it was installed more than 4 years ago, I'd replace it as they do degrade over time.
          • swifty
            • 63
            got to thinkin if im doin the dish i might aswell do the cable thanks for your help
