help pls
  • glynn47
    • 19
    help pls
    is there any one close to blackburn lancs who can line my moterised dish up its up on wall near guter realy struggling pls help thanks got all tools and ladder
  • mdt
    • 3034
    are you using a field meter?? regards mdt
    • glynn47
      • 19
      my m8 used a compass we just cant get 1 degree west so if u no anyone close who can sort it will pay them thks far reply
      • MrFug
        • 880
        If you think you're in the right direction you can use USALS without actually needing to lock onto your true south sat. Just enter USALS menu, enter long/lat and move the dish to 28.2. THEN get up and start moving the motor around the pole and tweaking elevation etc until you get a signal.
        • setfiretorain
          • Jul 2010
          • 934
          Yeah, what he said .
          Sat Boxes
          Dreambox 500s.
          Dishes
          Sky minidish self fitted.
          • dick b
            • Jun 2009
            • 2462
            enter the latitude of 53.8 North in your set top box and on your motor(these will not need to be adjusted again)enter 2.5 west in your set top box,put 11.862 H 28000 in the box for BBC World as your search TP. then using usals send the motor to 1West once motor stops go to the dish itself and put around 22 degrees on the elevation scale to start with then starting with the dish roughly pointing south twist the whole assembly slowly L/R til you get a signal if unsuccessful raise/lower the dish elevation and try again. it can be a slow process,I put a car exhaust clamp under the motor to make it easier to turn without it sliding down the pole.keep trying you will succeed.
            • mdt
              • 3034
              im going to go over and give him a hand this weekend, regards mdt
              • manxspud
                • 1768
                Your a true star mdt ...
                Ps ... do you cut hedges as well
                @manx
                • glynn47
                  • 19
                  cheers mdt my number 018018
                  took out your real phone number mate. saves you on dodgy phone calls
                  • mdt
                    • 3034
                    remove your number m8 ill send you a e-mail later on, regards mdt
                    • donkeyboy
                      • 410
                      looks like your gunna get some calls m8
