new blade media BM7000s-122p-08-04-11
  • elplicko
    DK Duf PT
    • 321
    hi guys this is not my work but here is the latest blade bm7000s firmware 122p-08-04-11 with 9991 menu and 7day epg enjoy and streaming software.
    ps update your channel list via blade online section which can be found in the menu>settings-astra 28.2e for the uk section this will get your 7day epg workin. DO AN EPG UPDATE AFTER!!
    the update does NOT affect any existing csline setting you may have so its safe to install even if you dont have the 9991 menu password.
    thanx goto galaxy for this.
    sigpicD.T.A. the safest way
  • stew86
    • Nov 2010
    • 236
    help
    i have been looking into the satellite side for a while because i am sick of cable side i like the blade media 7000hd is it used plug and play by that i mean plug the dish in scan for channels and get sly sports and movies etc any help will be a big help
    • ehabaziz
      • 5
      THANK YOU
      I think all of us has been waiting for that firmware, will try and feed back
      The box is spot on , using CCCam and 3rd party firmware, you can't go wrong on that
      bear in mind it is 3D ready box meaning if you have 3D ready TV , you are able to watch all 3D channels as well
      streaming from your own computer to the box, means no need for hard disc or media player to watch whatever you want
      for those who are wondering I think I am pretty much satisfied with the box
      • elplicko
        DK Duf PT
        • 321
        i gotta say after messing about with this for nearly 5 hours if u are using a diseqc switch for 13 east and 28 east when i scanned hotbird it found hardly anything and when i installed hotbird 7 day epg it said it was moving to 13 east.
        think whoever sorted this has a badly aligned dish, so i went back to 119p f/w 7 day epg not that impressive on sly uk
        • shermanator2uk
          • Apr 2011
          thanks for this mate, been waiting ages for an update
          • redondo5
            • 277
            I'm on a fixed mini dish on 28e and 7-day epg seems to be working fine so far...only tried it for about 1/2 hour so far but has picked up most channels for 7 days. Very impressive.
            What I did was update new channel lkist after firmware update using bladeonline menu option under settings.
            Then I selected ok, followed by yellow button for epg update. This didn't seem to work, so I tried going on the IEPG data (radio) audio channel and did an update while on that channel leaving it for a minute or two. Then when I checked the channels, the 7-day epg had appeared. Not sure if it was due to the radio channel but it defo works. I used that radio channel because I know this box is almost identical to the technomate 5402 box which also requires using that channel for the 7-day epg.
            One thing I would love is a better interface for the EPG, something similar to the VU+ EPG 7 day display would be sweet.
            Anyway, so far so good, will keep testing.
            • bri66
              • Apr 2011
              will this version definitely give us 7 day epg without screwing up our setups...bit dubious as this is the first unofficial update since 119 also win rar reports unexpected end of archive on downloading file...is it ok to use?
              • redondo5
                • 277
                As already mentioned by others, you will not need to reinstall the csinfo.txt file. But all other settings will be reset as far as I'm aware. Not sure about the channel list, as I just downloaded the latest one for 28e as soon as box restarted after firmware update. Another thing to note is that the epg disappears after a restart, so avoid putting box in standby if you want to keep epg or you will need to update on startup - takes 1 minute anyway.
                7 day epg works for sly uk. Description not there but titles are, which is very good for a box in this price range.
                Definitely worth updating
                Ps. You will need to redownload the file if winrar is giving you that error. Sounds like the download was corrupted or quit early. Redownload it from this thread if that still give you that error try google search with blade 7000 122p firmware. If that fails check disk space on pc or try using a different browser, firefox, chrome, opera, ie, safari
                • monsur
                  • 52
                  anyone used the blade strem
                  after i loaded up blade strem i cant get the 9991 menu to
                  show up
                  • jon48
                    • Apr 2010
                    • 147
                    7 day epg
                    mine;s not there m8 any suggestions...
                    • markedz
                      • 185
                      what does 9991 menu do for us with this box please
                      • trauma
                        • 74
                        Just came across this on sataid:
                        BM7000s-122p-08-04-11a [Released 26 April 2011]
                        The reason why we have not uploaded v1.22p, is simply because there is a fault/bug contained within it.
                        If you have the earlier firmware v1.22 installed, you should now replace it with this firmware BM7000s-122p-08-04-11a,
                        as the bug has now been correctly addressed.
                        • elplicko
                          DK Duf PT
                          • 321
                          hi maybe u could post the f/w here as registering on sataid is disabled
                          • trauma
                            • 74
                            I'm also waiting for registrations to open, I was hoping someone on here was a member, and could post the firmware here.
                            • teaml
                              been waiting 4this firmware 4 while can@t wait to try this 7epg ....thx
