Hello
After doing some research, I realised that Sky UK on 28.2e stream the EPG through a separate channel rather than the same channel which other satellite providers do.
What you need to do is find Sky UK EPG channel on your box
It can be found on this satellite stream
You need to manually tune it if you don't have the channel. The channel itself is found under radio rather than TV
Find 'IEPG Data 1' Under radio section on your box and stay on that channel for about 5 Minutes
If you have the CNDF file from blade, don't worry about manually adding the channel or if you haven't deleted it.
You should then have a full EPG, The longer you stay on it the more EPG data the Box Downloads.
I estimated about 10mins for a 7 day listing.
Astra 2A (28.2E) - IEPG data 1 - 11778.00 V - 27500 2/3 - SID 4189
