Upgrading
  • 51mon
    • 4
    Upgrading
    After using a Technomate 1600 CI for quite a few years I think its about time I upgraded. What would be the box to go for? I like the operating system on the Technomate so something similar would be good. I would also like USB PVR and HD. Any one got ant ideas?
    Cheers
  • tubs
    • 420
    Blade 7000hd a fantasitjc box and you will not be sorry
    • 51mon
      • 4
      Thanks for that Tubs, are they difficult to set up?
      • satmannwest
        • Apr 2011
        • 95
        technomate 5402hd pvr usb HD , same setup m8
        • andersjay
          • 53
          Ive just bought a tm5402, it seems a cracking little box so far. Very stable and very fast channel zapping. Half decent epg too.
          • tubs
            • 420
            It's a very easy set up and very easy to use well worth it and I help u if need be blade is great and I have had some boxes over the years
            • 51mon
              • 4
              Thanks for your replys.
              Would I be able to use an ethernet/LAN cable from my STB box to a laptop or does it have to come directly from the router? I do no want to run an ethernet/LAN cable around the house but my wireless lap top sits close to where the STB would be.
              Does the STB have to be connected to the internet all the time or just when updating the box? Is there many channels to get than I presently get on my old TM1600CI, I use a motorised dish.
              Sorry for all these questions but I must be years behind the new Tech.
              Cheers!
              • redondo5
                • 277
                Cheers!
                Techno ate 5402 and blade bm7000s hd are more or less same box. Both are pretty straight forward to setup.
                You'll need Internet access to the box to make the most out of cccam and other sharing facilities
                • cactikid
                  • 12017
                  look into home plugs for internet through your mains plugs as that can be used instead of running cables everywhere,they work great when on the same ring or connect 2 rings,like 2 circuits getting connected in house upstairs and downstairs.
                  Welcome to the world of dLAN? ... devolo AG
                  • setfiretorain
                    • Jul 2010
                    • 934
                    Your comfortable on your platform of technomate, The blades a good box, But the Technomate 5402 PVR USB HD is as equally as good from what I hear, stick to what your comfortable with, you'll have less problems, Of course that is if you want to be comfortable, if you want something now then yeah go with the blade !
                    Regards.
                    Sat Boxes
                    Dreambox 500s.
                    Dishes
                    Sky minidish self fitted.
                    • 51mon
                      • 4
                      Thanks everyone TM on its way
