Delete please.
Protek 9600IP Question
you will need to flash your box when you first get it unless its pre-flashed for you but after that the sw updates are automatic and just require a couple of button presses to update. ive installed over 30 of these boxes (and clones) over the last 3 or so years and every single one is still working as far as i know and the team behind them are very good at what they do with frequent updates as and when they are needed. regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
most dealers wont flash a stb before selling it as it can cause legal problems although its usually the small time e***ers who do this. you will know if the box is flashed as it will clear the packages when you connect it to your router/lan cable. the latest software can be found here on dk and flashing the box is like any other that uses a null-modem cable by using a uploader to load the .bin file. regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
...and refering to your 1st Q, You will need to connect to a satellite dish & NOT a standard TV aerial.Hi, I am thinking of getting the Protek 9600IP Box and I have two questions.
1. Do I just connect the box to the aerial and my router without installing anything?
2. Will I get the sports channels like Al Jazeera Sports & Sky Germany without having to install anything on the box?
So basically will I get these channels just by switching on my box and doing software updates through the box?
Any help is very much appreciated.
A standard Sky dish will do for UK FTA channels or a larger motorised dish for even more european sats/channels.SLOWLY, OUR FREEDOM IS BEING ERASED.
SOON, WE WILL JUST BE A NUMBER.
IF WE DON'T FOLLOW, WE WILL BE ERASED.Comment
