technomate 6900
  • gracieboo
    • Dec 2010
    • 368
    technomate 6900
    Hi there can someone give me a bit of advice. I currently have a technomate 5300 on a motorised system. Im thinking of getting a technomate 6900 as i know of one going cheap. Would this be a straight forward swop of the boxs or do i need to change my single lnb for a quad to get two coxial feeds or is the single ok. I know sky hd has two so you can record a channel and watch another channel. Any help would be great thanks.
  • thijs
    • Apr 2010
    • 1096
    the 6900 has a single tuner for the satellite so single lnb is fine
    and it has a tuner for the freeview with your aerial.
    record one channel and watch an other on same transponder only.great box also for cccam if it's a super (with lanport)
    with the tm 7100 or 7102 triple tuner you would need quad lnb or duo lnb
    Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.
    • gracieboo
      • Dec 2010
      • 368
      Thanks for your help i take what your saying is that a straight swap of boxs is ok then.?
      • dick b
        • Jun 2009
        • 2462
        yes that will be fine you will regognise the menus ok just make sure you input all settings the same as your old box.lat/long etc:
