Streaming on Blade 7000
  • n14
    • 6
    Hi folks
    little bit stumped with the streaming. have downloaded stream exe. have entered local ip address on the blade. but how or where do i create or find "media and channel file (.CDF) folder" ?? all i have is my films in a folder on pc, but obviously the blade is not recognising this file ?? anyone give me some advise please
  • trauma
    • 74
    Are you running the latest version of BladeStream it should be v3.20.
    And during the initial setup, you should have had the option of selecting a folder to connect too.
    There is a tutorial available that demonstrates the whole setup procedure, but as it's located on another forum, I shall PM you the link too it.
    • thfccambs
      • Oct 2008
      • 23
      Could i have it also please?
      • johnviv
        could i have it to please
        • shearer9uk
          • 103
          blade media 7000hd
          hey doods, how is the machine ?
          looking at getting one when the twin tuner comes out.
          how is for the cccam ??
          many ta's in advance.
          • tabletop
            • Jun 2009
            • 40
            Originally posted by n14
            Hi folks
            Hello there, I'm in exactly the same predicament (its driving me nuts) saw tutorial good but little help to me I've downloaded software unblocked firewall no probs. when I click (...) where is the folder that I want and how do I put my movies etc. into it? I'm sure its easy when you know how, but I'm stumped, Please help me if you can, thanks.
            • zee24
              • 3342
              what's this all about? what can you stream?
              • happy_highlander
                • 3535
                Avi Files from your pc mate same as with the tm 5402,
                • ramjet
                  • 2995
                  BLADE STREAM
                  Blade Stream is very powerful software that runs on any Windows PC which will allow a BM7000s to connect direcly to that PC and stream movies, or download firmware or channel data files directly.
                  The software does not need any install. It is available at Blade Media in the support pages.
                  1. Simply unzip Blade Stream folder to desktop (or your chosen location) and run BLADE Stream.exe
                  2. Windows Firewall will ask you to allow access - say YES.
                  3. Next, on Blade Stream, click '...' button to browse to your media and channel file (.CDF) folder and click OK. Blade Stream will now minimise to the taskbar and is now ready to stream.
                  4. On your Blade Receiver, press PLAY (or F1) on the remote and press YELLOW to ADD OR SELECT SOURCE. Press Blue button to ADD or CONNECT. Here you type the local IP address of the PC that you just put the Blade Stream software on, for example 192.168.1.3 etc.
                  Once you enter this and press OK you will see the directory list of your media folder. Now you can play any movie from your PC just by selecting it, or load any firmware or channel files in the list.
                  • zee24
                    • 3342
                    ive followed the instructions but when i type in the i.p address it keeps saying connection failed. ive gone to whatsmyadress to find my i.p ive checked in command prompt both of which look different the whatmyipaddress starts with 77.97 the one in command prompt after i typed in ipconfig/all starts with 192.168 ive even tried the DNS server ip but all seem to fail ive allowed the firewall access aswell, any ideas?
                    • happy_highlander
                      • 3535
                      Bring up a command prompt and type in "ipconfig" this will bring up your router ip which is often 192.168. Etc ending in 1 and also your your local ip which is the comp you are working at with your files stored on and dream stream. Not sure what ip you need for blade maybe both or just local. I know you have tried most of this but it is usually not the router ip but the local which if memory serves me correctly is ipv4 or something like that, I may be wrong I quite often am, that may be your router
                      • ramjet
                        • 2995
                        the correct ip address is the local LAN one your pc is using and will be 192.168.xxx.xxx , so something like 192.168.0.3
                        it is not the blade ip address, and not the router ip address either
                        it is most definitely NOT your isp ip address as that is your internet access from your isp (the 77.97 one)
                        so you are looking to assign a folder on your computers ip LAN address where the blade can find the files it requires
                        so basic knowledge on LAN ip addresses is required here (local networking)
                        • zee24
                          • 3342
                          i have tried the ip but it still fails to connect don't know what to do now.
                          Ive made a folder dedicated to bladestream where ive put some avi files in to, when i click the '...' icon and assign the folder to bladestream and click ok it comes with an error message 'not found dll'
                          it didn't when i first assigned the folder couple of days ago.
                          • ramjet
                            • 2995
                            maybe you havent unpacked the bladestream tool folder correctly ?
                            you should have a data folder in there containing dll and other files too
                            • zee24
                              • 3342
                              ive re installed it and error message doesn't come up now.
                              When the firewall message came up again i allowed it again, there were 2 tick boxes that were there 1 said Todo public and 1 was for private for the home i ticked the private box is taht right?
