lost all Satellites apart for Astra 19 E
  • latinemariner76
    • 18
    i have dreambox800 hd,and electric went last night and when i switch it back on i lost all the channels and satellites
    when i click on setup--> Tuner configurations-->advance-...> i can only see Astra and nothing else is there
    please help
    many thanks
    Is it a motorised dish if so are you using Usals,change configuration mode to simple and check your lat and long are still entered there
    • latinemariner76
      • 18
      yes it is motorized dish and my lat and long is there
        Keep it on simple mode and save and exit.
        • latinemariner76
          • 18
          yes done that, what next
            Reboot box and see if it's back on. When i go to advanced mode it only shows 19.2 on my box too.
            • latinemariner76
              • 18
              mmmmmmmmm still nothing bulld0g.
                Have you tried ftp'ng another list over ? I use these for my motorised dish http://www.digital-kaos.co.uk/forums...post1086907you can alter it to suit you if you want using Dreamboxedit
                • latinemariner76
                  • 18
                  tried ip and user name is root and passowrd as dreambox but keep coming wiht incorrect password
                    You haven't changed your password ? Try this to change password
                    Open DCC and make sure ip is correct.
                    Clear the password in box provided
                    Press reconnect
                    Go to telnet
                    Type "passwd"
                    You will now be asked for new password.. type your new password.. Then enter..
                    You will be asked to retype your new password
                    You should now have a new password
                    • latinemariner76
                      • 18
                      how do i do DCC
                      i really appreciate your help
                        Get a copy of DCC its here if you don't have it Digital Kaos - Downloads - Dreambox Forever
                        Open it up and put the correct ip addresses in, on the left hand side delete the password then go to telnet and follow the instructions in my last post.
                        If for some reason you cant do it the only other option is to reflash the box, if you do this by web browser it only takes a couple of minutes
                        • latinemariner76
                          • 18
                          yea i have done that but still no luck, problem is if i re flash it i will lose all clines for my channels, if you know i mean
                          • Shady
                            Shite Link King
                            • Dec 2010
                            • 6404
                            copy ur lines before you do it.. theyre only lines of text mate
                              I don't think he can get into the box for the config file shady
