SKY IN 3 ROOMS
  • drewster
    • 12
    SKY IN 3 ROOMS
    Hi i have sky in another room using magic eye,i was wondering can i have it in another room aswell i know the same channell will have to be watched so i would need another magic eye .Can some one give me the answer?
  • terriers
    • 580
    yeah just buy a 4 way tv link..you can change chnls in all rooms,but obviously you will have the same chnl viewable in all rooms...u can also get a 6 way tv link
    • satmannwest
      • Apr 2011
      • 95
      any passthrough amp will do the trick.
      • drewster
        • 12
        How would i set up the 4 way tv link?
        • terriers
          • 580
          it plugs into rf 2 on the box and turns it into 4 outputs all carrying the 9v needed to work the magic eye...run a cable to the required rooms attach a magic eye to each and now all rooms can turn the chanels over on the sky box
          • satmannwest
            • Apr 2011
            • 95
            Dont forget to turn RF2 On in the menu otherwise magic eye wont work.
            • drewster
              • 12
              Right done what you have all said,but the cable i want to work in the bedroom doesnt seem to work the magic eye light doesnt come on but the one in the lounge works fine?any ideas whats wrong?when i set everything up the magic eye light came on for 2seconds then went off and never came back on.i also switched magic eyes the same happend.
              • bj1
                • 445
                check your connections m8 if just one strand of the brail is touching the inner core it will not work, if you have set everything up the way terriors told you it will work.....
