home plugs
  • alom5
    • 1648
    #16
    Originally posted by plasterer
    Yes i heard the same thing ,but cant confirm this .
    If all your downstairs sockets blow a fuse and your upstairs sockets are still working
    This would indicate a diff circuit and these may not work
    Can anybody confirm this ,Cheers ............Paul
    i can confirm this is the case.
    i had belkin ones and they didn't work in such a sittuation. but worked great on the same circuit.
    • setfiretorain
      • Jul 2010
      • 934
      #17
      They all work the same tbh.
      Sat Boxes
      Dreambox 500s.
      Dishes
      Sky minidish self fitted.
      • markedz
        • 185
        #18
        bought the xenta 200m
        cant seem to get them connected
        0 powerline detected
        they are in same room at the moment next to each pther on same extension lead still nothing
        any ideas
        • Fergal
          • 1007
          #19
          Try plugging them directly into the wall sockets not extension leads.
          • markedz
            • 185
            #20
            nothing at all
            • Fergal
              • 1007
              #21
              Silly question but you are plugging one into to your router and the other one into the box and have ticked DHCP in the network settings on the box and rebooted it
              is there a pairing button on them you might need to press both
              • markedz
                • 185
                #22
                i have a blade 7000hd
                and i plugged into box and router with eth/leads
                i had a disc with these put that in loaded as it said
                but cudnt find these plugs on the power packet utilty
                where is dhcp on a blade box
                i have dhcp usage which is on
                • mark8393
                  • 2305
                  #23
                  try using different ethernet leads, then just press buttons on bottom of plugs
                  • markedz
                    • 185
                    #24
                    tried 4 eth leads 2 i no that work
                    surely my comp shud pick em up
                    • markedz
                      • 185
                      #25
                      retried these today and hey presto they are working
                      amazing
                      thanx for all help
                      • plasterer
                        • 1631
                        #26
                        Should have saved your self a few Notes mate
                        Plug Enthernet into your Lappy
                        Other end into your box
                        Go to Network Connections
                        Highlight Both Connections Right Click and Bridge
                        Job done no expense needed
                        Hope this Helps ................Paul
                        If your Happy with the Help push the Thanx button
                        PAUL
                        • Fergal
                          • 1007
                          #27
                          But he would have to keep his lappy plugged into the box and switched on all the time which is not a good practicable solution Paul.
                          • plasterer
                            • 1631
                            #28
                            Yer forgot to mention that mate
                            I sometimes watch a live game in the bedroom
                            And have it bridged for 90 mins ....................Paul
                            PAUL
