1m satelite dish mounting
  • sparktikus
    • 31
    hi all
    im delving into the world of motorised statellite
    got a 1m dish and technomate 2300 motor
    im going to mount the dish at bottom of garden in between fencing and shed theres bout 1m gap in between,
    now i have some t & k brackets and was going to mount these with scaffold pole onto a 6ft concrete fencing post
    question is would this be suitable and stable to mount to because obviously i would ony be able to attach t & k brackets on their centre line on concrete post??
    also any tips advice on getting started with dm500s and this set upi wanna get prem footy for next season i am in west mids.
  • owenb
    • 703
    hi mate not sure if i got this correct but can your dish turn freely in the space that your are giving it? are u going motorised i presume you are or the 1m dish is huge overkill
    • sparktikus
      • 31
      yes mate motorised, i will be able 2 get the swing of the dish because im gonna mount it height wise just above fence & shed
      does my plan sound ok
      • owenb
        • 703
        yes mate sounds fine as long as nothing is in the line of sight of the dishes arc buddy
        • satmannwest
          • Apr 2011
          • 95
          I wouldn't drill any holes into a concrete fencepost as they become weak when drilled because of the steel reinforcement, you would be best digging a hole a couple of feet and concrete the pole into the ground making sure it is completely plum using a level
          • MrFug
            • 880
            I'm not sure if I understood right but are you planning to secure the T & Ks to the concrete pole by only bolting them in through their centre holes?
            • billyboy2011
              • 25
              Use Patio Mount
              I use Non Penetrate Flat Roof Mounts (NPRM).
              It can also be used as an alternative where there are no means of mounting a dish/aerial to a wall/chimney.
              Check out fleabay or google NPRM
              I found item 300559773143.
              You just put 4 standard concrete flags in the square base of the mount and attach you dish to the mast that stands up from the centre of the base. Very easy!!
              Good luck
              • Shady
                Shite Link King
                • Dec 2010
                • 6404
                are you the ~~~~ing seller billy? thats twice you've recommended that item for sale now
                • billyboy2011
                  • 25
                  Dam...my cover is blown...
                  I wouldnt have a starting price..fleabay is for bargains *-)
                  • pillapow
                    • 3323
                    Good luck
                    How do you find plumb with these mounts if the ground is slightly uneven ?
                    I am obsessed with Liverpool Football Club, I think you are too !
                    • Curious123
                      • 2591
                      I dug a hole at the bottom of my garden and concreted in a 12 foot scaffolding pole and mounted the motor directly onto the pole. I have never had any problems with the dish though I could have done with something at the end of the pole in the ground in case the pole turned after a few years.
