loft install
  • amcfad
    loft install
    Hi all, are there any downsides to setting up a dish inside a loft space ? if not anyone got any ideas for a good set up.
    Cheers andy
    p.s i stay in glasgow does being so north make a difference ?
  • krazylegz
    • 2834
    not possible to install in a loft m8 as satellite needs clear view of the sky
    PS3= krazylegz120282
    • opsmonkey
      • 5379
      the only inside install you can have mate is a dish in front of a window..
      a satellite dish will work through glass but its efficiency depends on the type of glass and the dish size. eg.. for Sky Digital you'll probably need at least a 60cm dish to compensate for the signal loss in the glass as opposed to a 43cm one outside..
      being so far north will impact a bit but you'll still get a lot of good sats..
      • .: JaCkPoT :.
        Retired Sat TV Addict
        • Aug 2008
        • 5607
        You could install it on a pole and stick it out of the loft window if it has one..
        ___________________
        In the good old days, I had
        DM800s HD
        Openbox S10
        TM500
        DM500s
        90cm FortecStar dish
        Maxx 110cm Dish
        Technomate 2300 Motors
        • opsmonkey
          • 5379
          how rich are your parents..? not everyone has a loft conversion young man
          anyways loft windows only open to a max of 45degs.. you couldnt get a dish out of that
          • .: JaCkPoT :.
            • Aug 2008
            • 5607
            Our loft was converted before we moved here .. Just snap the hinges.. That should do the trick..
            ___________________
            DM800s HD
            Openbox S10
            TM500
            DM500s
            Maxx 110cm Dish
            • amcfad
              thanks guys, the loft in question is shared with neighbours, just trying to get my own dish setup as i am unable to attatch dish to outside of communual building ! bah humbug ! need to get another cunnning plan, any ideas ?
              • benny/9
                • 1964
                is it part of your agreement or is it a listed building etc:that stops you from fitting a dish to the outside wall? my brother lives in a block of flats and he fitted a dish to the wall outside one of his windows he is three floors up, or if your building has a flat roof can you not get a dish fitted on the roof
                Please Read Carefully!
                • Neil
                  • 194
                  You can install a pole that goes through a 'false' slate on the roof. This keeps the roof weather proof but allows the pole to be fastened inside the roof space.
                  500c, 600c, 7025+cc, 7000s with a 1m steerable dish
                  • .: JaCkPoT :.
                    • Aug 2008
                    • 5607
                    thats clever..... but wouldn't that mean the pole would be very wobbly???
                    ___________________
                    DM800s HD
                    Openbox S10
                    TM500
                    DM500s
                    Maxx 110cm Dish
                    • opsmonkey
                      • 5379
                      no mate i think it would attach and be on a ground mount in the loft, then go up through the roof..
                      can you provide a link to such an example.. ive never heard of this.. or is it a home made jobby
                      • cauliflower69
                        • 261
                        Does anybody know about the things that you can use to install an aerial to a roof not the chimney.
                        Thanks for any help.
                        • .: JaCkPoT :.
                          • Aug 2008
                          • 5607
                          Never come across anything like that before.. Either way i doubt it would be strong enough to hold a motor and a wind affected dish either....
                          ___________________
                          DM800s HD
                          Openbox S10
                          TM500
                          DM500s
                          Maxx 110cm Dish
                          • alunfennell
                            • Oct 2008
                            • 1525
                            I had a setup like that, but with high winds it rattled every so lightly because the support beams are holding the pool at the base it moves & also been on the roof there is no shelter from Wind, Snow , Rain, I ended up moving it off the roof and putting it onto a Sheltered wall on the side of the house and the reception has been improved especially in inclement Weather, my advice keep it off the roof if you can.
                            Regards:
                            Alun
                            **The Worlds Best Interactive F1 Strategy Game**
                            • Walkinmyshadow
                              • 712
                              As a Carpenter can i say if you get the pole done properly you should have no worries about "wobbling", What you basically need is a pole to go from the floor of the attic room and to protrude out of the roof at least a metre, the pole itself would need to be about 40mm in diameter and fixed at the very bottom, middle and as near to the top of the pole as possible inside the roof, This "false slate" as you call it is known as a macflash, its basically a sheet of thin metal about 40 cm square with a rubber sleeve in the middle that allows the pole to protrude through it, Most builder providers stock these, but make sure the sleeve is suitable for the pole diameter otherwise it will leak, if the shop hasnt got the correct side in stock it can be ordered in
