newcamd is a cam.. a cline goes INTO a cam to enable a c/s.
ur better off getting cccam instead of newcamd
1: What the fff is all that about??? All that crap below your reply I mean, get a life mate 2: no info on google abt the pace sv5 rang asda they have no idea what i was talking about, 3: Your total contribution to this forum, bordering on trolling, seems to have been a collection of snipes, one liners & asterisked expletives
I would like a bit more info on this also please, hope you dont mind me asking, I give out Newcams and also i get newcams and also get cccams, The ccams sometimes struggle to connect but the newcams connect stright away, but with the newcams i give out sometimes the connection is lost at the other end after i have turned the tv off and gone to bed!! the box is still on which they get the line from, any ideas y??
the spiderbox is known to have problems with certain versions of c**am (although others will say different) so if possible keep to 2.12 and under. newcamd is basically the same as c**am although you tend to need 1 line per providor/package. regards mdt
But you can mix? also is it best to have Service+ on or off or does it not make a differance??
i dont know if you can have both systems running at the same time on a spiderbox as i never tried it when i owned one but i dont see why not.. you could always try. as for the service+ being switched on or off then it shouldnt make any difference according to the team behind the box. the reason why i got rid of my 9000hd was because of the disconnection problems and problems with dvbs2 feeds(both these problems have been fixed according to the team behind the box). id say try doing some tests with different versions of c**am and newcamd/fixed ip/dchp ect ect and see if you can get your box running stable.. if you cant get rid and get a vu+duo/dm800hd like i did. regards mdt
Hi I've got both running in tandem some cancel each channels out both glitchy but for wat I pay can't complain. I still have service+ on swell!!
I dont pay just can't understand y all my newcams work all the time but the ccams are hit or miss, as i speak all newcams connect each with one card and my ccams trying to connect but cant!!
