  • palski
    • Oct 2008
    I`m just new user and just look around to find the best image for my DM800 clone, get this ca error all time /palski
  • mdt
    • 3034
    have a look in the dreambox section and do some reading. you are getting NO CA FOUND because you are using images with the wrong bootloader/sim. ask for help in the dreambox section giving as much info as possible and somebody will help you if they can, regards mdt
    • MrFug
      • 880
      If you get CA ERROR then you've flashed an incompatible image for your sim version. You'll need to use a null modem cable to recover from it.
      Make sure you only install images that are compatible with your box.
      • palski
        • Oct 2008
        Yes today i used my null modem cable a lot, because of incompatible image file, I found here in the download section a lot of image with 2.01 76 and it is working now Thanks guys /palski
