bbc one HD and bbc HD change
On the 7000HD...
Menu > Installation > Channel Search (0000 PIN)
Scan Mode = Manual, then press the green button Add TP
Change the frequency manually to 10.847
Change the symbol rate to 23.000
Polarity should be V
Press red button to scan
That should get your BBC HD channels back.Comment
Starview HD Combo
Hello guys im a newbie. well guys i just wanted to know as the cable side of starview is gone down since feb but i have just tried my starview combo box through a skyuk dish and it connected through a router i even got a test line but my box says hs net disconnected. any one can help and by the way i am using the latest carling+ too which is i fink f531. thanks help would be much appreciatedComment
cheers m8On the 7000HD...
all back nowComment
ishal
im in the same boat mate and if i work it out i will post back. wont pick up after a rescan and cant seem to change to 23000
must be a way though. lots fo people on sly side with hd combo.Comment
a handy place to check new frequencies of sat channels when they start to go because of closure or movement.
KingOfSat - European Satellite Zapping & DirectoryComment
