setting up motorised dish
  • danped
    • May 2011
    • 31
    Hi,
    I've read through the guides about setting the latitude on your motor using the bracket, but there is also a bracket on the dish. The problem with this is that the angle on the dish has a minimum setting of 5 deg.
    The guides I read suggest how to set the angle on the motor but none seem to have mentioned the angle on the dish? Am I right to assume the sum of the two need to be the inclination angle required for your location?
    Thanks.
  • andymc1s
    • 694
    use the following link and enter your address hope this helps.
    Satellite Finder / Dish Pointing Calculator with Google Maps | DishPointer.com
    • Manic01
      • 5117
      Thats for fixed dish.
      Long and lat will be ok but rest is for fixed.
      • mdt
        • 3034
        dont worry about the angle on the dish... i just set it to 30 degrees and then ajust for best signal but the pole being 100% plumb and the lat on the motor(for your location) are critical. if you get stuck the just ask in this thread and someone will help you. regards mdt
