starview hd combo sat side problems
This topic is closed.
  • mast
    • Nov 2010
    • 1027
    #16
    Hi
    I used grooverider hd combo+ 1214.uad, not sure about the one used.
    I would reflash with the fix and then put on one of the ones some of us have said and then put on either carling or knightrider.
    That should sort it.
    • mast
      • Nov 2010
      • 1027
      #17
      Originally posted by faizyan6000
      hi what is the latest nightrider or carling software for the starview hd combo
      Hi
      Carling+ F531 and knightrider+ 0825, think them are the latest. Someone will correct or comfirm if Im wrong.
      • faizyan6000
        • Feb 2011
        • 37
        #18
        i have just downloaded the carling+ f531 see how it goes
        • mast
          • Nov 2010
          • 1027
          #19
          Hi
          Well you should find out in a few minutes......good luck.
          Did you change the grooverider firmware to the ones weve said.
          • faizyan6000
            • Feb 2011
            • 37
            #20
            yes i have now flashed the carling+ software and am now scanning all channels
            • STEVE MACQUEEN
              • 48
              #21
              Don't know mate, but the ones I've posted are the ones I use and they def work.
              • mast
                • Nov 2010
                • 1027
                #22
                Hi
                You seem to have it sorted now, I need to call it a night so hopefully you wont have any probs.............. well this is where maybe the fun starts and you `l have more questions .
                Most of the answers are in the threads but if you need to ask, Im sure someone will be able to help.
                • faizyan6000
                  • Feb 2011
                  • 37
                  #23
                  the problem is still persisting the cline shows its connected but the channels come up scrambled have tried to rebbot the boox still coming up scrambled can anybody help
                  • reaper101
                    • 80
                    #24
                    i had the same problem the server where i got the cline told me to delete the DES key
                    it now works !
                    • faizyan6000
                      • Feb 2011
                      • 37
                      #25
                      i will try that when i get home tonight and ill post the result afterwards
                      • mast
                        • Nov 2010
                        • 1027
                        #26
                        Hi
                        You may shut off via the menu so the box stops trying to connect to cable server, cant remember how on carling as Ive got knightrider on...... that will stop causing conflicts, not saying thats your problem but it can only help.
                        Also how are you inputting your cline I had to take off the C: or N:
                        • faizyan6000
                          • Feb 2011
                          • 37
                          #27
                          i havent had the chance to test it yet as when i went home on friday my internet was down rang the the provider up and it seems i have a faulty router so they are sending me another one hope to recieved at the latest tomorow
