cheapest sat box and dish
  • markedz
    • 185
    i already have a blade box running uk sly
    but now i want to watch 3pm footy
    so whats the cheapest box and dish i can get to watch 3pm footy,and the best sat to get 3pm footy
    and is it ok to place dish by my sly dish,or move it elsewhere
    tia markedz
  • andy91
    • 3583
    Depends if you want hd or not,
    If not you cant go wrong with a Dreambox 500s and if you want hd then the Dreambox 800hd.
    Dish size you want 85 to a 1 Metre cos you will want to pick up Hotbird 13,alot of footy on there.
    Would have thought your Blade does the same job as the Dreambox.
    Pay about 170 quid for a motorised set up supplied and fitted.
    If not fix one at Hotbird 13.
    Andy.
    • markedz
      • 185
      may just use the blade then
      can i connect 2 dishes to this blade box
      • Curious123
        • 2591
        You would need to get a DISEQC switch so that you can have two inputs going into one reciver.
        • markedz
          • 185
          any particular one
            this one will do GT DiSEqC 2.0 4 x 1 way Satellite Switch | eBay or a 2 way one will work fine to but buy the four incase ya decide to add more satellites or lnbs to your setup
            • Curious123
              • 2591
              I was looking at the site selling the switch and noticed they were selling two lots of multifeed lnb holders where one was curved and the other was straight. Why would one be curved and the other straight?
              • markedz
                • 185
                gonna buy just a dish to fix at Hotbird 13
                any ideas on best or cheapest place to get a dish,oh and a sat finder
                • markedz
                  • 185
                  anybody ???
                  • Curious123
                    • 2591
                    anybody ???
                    I got my dish and motor from wizard satellites but I think they have changed to Wizmaster. If you are only after the dish then Fleabay is probably your best option.
                      anybody ???
                      the sky one will do ya mate can get them for nothing
                      and ya wont need a sat finder if ya simply run out an extension cable and a portable tv
                      hook up box and set sat to 13.0
                      then look at signal strength on tv till ya pick up a good signal then just tighten it up
                      • andy91
                        • 3583
                        Will a Sky mini dish be big enough for European sats?
                        I was told to get a 80 cm dish before thats all.
                        I guess alot depends on which part of the UK you live.
                        Andy.
                          well the sky dish in ireland works here its 60 cm
                          • Ansem
                            a sky dish is fine for either 13e or 19e
                            plenty of footie on them
                            • sinky077
                              • 66
                              box
                              hi m8 iav got a sky dish wat would be the best box 2 get .and do i have 2 do. c/s. 2 get the 3 pm footy thanks for ny help
