line up to hotbird....press menu on box and go to antenna settings select settings on disesc and change to switch from A TO B..... A will be hotbird and B will be 19.2 e, on your box [protek] press blue button and select premier select a channel if you are not picking up any signal it is best to run a cable from your loop out on back of box up to your meter at the dish then turn the lnb to around 2 oclock untill you start picking up your best signal, go back to box and select a channel on hotbird do the same again untill you have a decent enough signal on both sats.......BJ1
