hi all in need of help of a motorised dish specialist please got dish up just need alligning to 1w im in tamworth staffordshire if that helps many thanks
motorised dish installeer
Why not try your self. It probably is a offset dish so obtain a cheap satfinder meter. Connect in line with receiver and LNB. Make sure your Elevation is set on motor
Have your dish just pointing upright and LNB pointing South. Move it left and right. If nothing Tilt it a few degrees back say 92 degrees. Do that until hear something on the meter. Adust the meter so it shows about 80 percent, Now just fine tune it until you receive the best signal. First left and right , and carefull tighten, and then elevation. Don't forget to adjust LNB to the best signal. -
hi peter there is a usefull sticky at the top of this section how to set up motorised dish and also one for fine tuning these will give you all the help you need and is free.....BJ1Comment
