want a box if some one realy help me out please
  • C64
    • 2394
    #16
    Originally posted by krazylegz
    i think you are trying to run before you can walk m8.....try setting up the box to receive currently hacked channels before you attempt to stream or cardshare.
    there is loads of images about all do basicly the same thing opening the same channels...most just have different GUI and plugins...however stay away from gemini images.
    all images open the same channels as its down to the emu that opens them...eg....mgcamd, evocamd, CCcam
    so my advise to you is flash a image...say DK1.1 or nabilosat.....connect it to router or cross over cable and transfer over keys......then scan what ever satellites in your case 28.2e (skys satellite) then connect to the interent if not already done so and download a emu from the images addon server...
    .....get used to this bit before you try anything else
    Good post mate.
    • sunlight786
      • 57
      #17
      you guys make my day while last week i was so upset because not getting starting point from any where...thanks GOD i am here among experience peoples.
      Any way you all agree i have to buy dreambox500-S?
      any body selling it? OR try google search? ALSO i believe i am OK with current sky
      dish position to start this mission????
      • C64
        • 2394
        #18
        If your dish is pointing at 28.8 (Sky digital) then you will only receive FTA channels (also FTV is you have a card). It'll be enough to get you up and running for test purposes.
        What route are you looking to take?
        Is it your aim to get Sky TV for free?
        • thered
          • Aug 2008
          • 4915
          #19
          to make the most m8 your better to get a dish of 80cm+ or as big as you can and a motor to get the full benefit of a satellite box
          • sunlight786
            • 57
            #20
            Is there are any fix point to getting full asian pack,,,,,sports pack,,,movie pack,,,,,
            i understand currnet Dish on sky piont will give me only fta chanels and its good after sending the image to box and test???
            do i realy need MOTOR????CAN big size dish WILL DO THE JOB ?
            • C64
              • 2394
              #21
              A bigger dish means a stronger signal.
              It's not essential that you go motorised but it is the best option especially if you want to pick up other satellites.
              You can fit a special type of bracket onto your LNB arm which will angle extra LNB's so that they will pick up signals from other satellites, if you are doing this then the bigger the dish the stronger the signal you will get on the satellites that are not the prime focus on the dish.
              • opsmonkey
                • 5379
                #22
                Originally posted by witchy2k1
                Since when do you need to 'learn Linux' to setup a Dreambox or any other linux based box?
                cfg and .prio files are written in shell script
                • mm009b
                  • 221
                  #23
                  Originally posted by opsmonkey
                  if you really dont understand it mate, i would consider not getting a dreambox..
                  too many people buy a dreambox and think:
                  "i can do that, sounds easy.."
                  its not
                  lighten up opsmonkey the guy only asking we all learn and yes its hard and takes many long nights show him your xmas spirit give him a cuddle
                  • sunlight786
                    • 57
                    #24
                    OK GUYS I RECIEVE MY FIRST DRAMBOX500-S TODAY.I DID NOT DONE ANY THING WITH IT APART OF UNRAPPING IT.SO WHERE I AM GANNA START??
                    • thered
                      • Aug 2008
                      • 4915
                      #25
                      stickies in red in satellite dreambox and stickies in cable dreambox will also help
                      • sunlight786
                        • 57
                        #26
                        can you tell me what i need to check first of all and do i need to flash it wi th any image first????i got astra 28.2 at the movment (standerd sky dish)
                        • .: JaCkPoT :.
                          Retired Sat TV Addict
                          • Aug 2008
                          • 5607
                          #27
                          As mentioned before any image apart from the gemini...try dk1.1,darkstar or Nabilosat images..
                          ___________________
                          In the good old days, I had
                          DM800s HD
                          Openbox S10
                          TM500
                          DM500s
                          90cm FortecStar dish
                          Maxx 110cm Dish
                          Technomate 2300 Motors
                          • sunlight786
                            • 57
                            #28
                            will you guide me the link for downloading the Nabilosat image??plz
                            do i have to flash it via universal dream up???thanks
                            • krazylegz
                              • 2834
                              #29
                              which nabilosat m8?? i always prefer to use dreamup or you could telnet
                              PS3= krazylegz120282
                              • sunlight786
                                • 57
                                #30
                                right now i am flashing with universal dreamup by usin this image Darkstar2_DM500
                                is that OK?
