kryptview to sat move . noob questions
  • redeye094
    • 82
    hi all .. thinking of moving over to sat, few questions
    i have my old dish in loft - can i reinstall on side of house (fixed) and point in correct location
    want cheapest box ( not bothered about hd or twin receiver ) - if flashed is it simply plug and play
    once working are there regular updates needed or just simply works
    many thanks
  • billy2
    • 1381
    (1) i have my old dish in loft - can i reinstall on side of house (fixed) and point in correct location
    yes as long as it is the right size to pick up the sat location you wont
    (2) want cheapest box ( not bothered about hd or twin receiver ) - if flashed is it simply plug and play
    cheapest box is about ?50 give or take, after flashing and doing a scan for the channles it is plug and play for the free to air channles only anything else needs more work and need to read the rules about this or google
    (3) once working are there regular updates needed or just simply works
    when set up right it simply works (and need to be hooked up to your network ( Internet) if looking for more than free to air channles
    good luck
    • redeye094
      • 82
      thanks billy
