Blade 7000 how big is the Hard Drive
  • nsw9154
    • 259
    i fancy moving from cable and getting a Blade 7000 but i can not seem to find out how big the built in Hard Drive is i presume that it must have one fitted to be able to record 2 programs together
    i have read every reviue and info on said box but still can not find any info any help would be apreciated thanks in advance
  • mark8393
    • 2305
    No hard drive installed, you need to buy an external one.
    • cactikid
      • 12017
      they should also state a make and size to use as some dont work,if anybody has one working add the name and size please
      • nsw9154
        • 259
        i know that you need a Fast USB 2 external Drive but i thought that it had one built in as well
        • ratts
          • 12
          im using my old sky box hard drive.
          western digital green 320 gig
          • joetwizzy
            • May 2011
            • 322
            I also assume it must be a mains powered HDD. My 2.5" USB powered one does not work, although I assumed it wouldn't. Need to find a cheap one that will record HD perfectly .
            • cactikid
              • 12017
              you can get a caddy for hard drive to make it external,i see ratts has the knack of recycling
              • ratts
                • 12
                i just put it into a caddy mate, which is mains powered.
                as regard to your 2.5 did you format it too fat32 first.
                if you go to the blade website you can d/l there hard drive format tool.
                • ratts
                  • 12
                  up there for thinking and down there for dancing mate
                  • cactikid
                    • 12017
                    wondering what else you found in there
                    • zee24
                      • 3342
                      any recommendations on Hard Drives for the blade? has to be cheap tho
                      • joetwizzy
                        • May 2011
                        • 322
                        No I didnt bother as it didn't even spin.
                        On that subject. Fat32 cannot use a file over 4gb if I remember correctly. Would it save HD programs in multiple files? Does it handle them well.
                        • lewisqpr
                          • Jul 2011
                          • 4
                          It save the videos you record into 4gb .TRP files and it creates multiple files depending on how long your record is. So you could end up with 2 or 3 .trp file on the hard drive for a 2 hour program you recorded. However the box only sees the multiple files as one file and they play well on the box but they can be a bit awkward to play on the PC.
                          • ozzie11
                            • 33
                            On this topic, has anyone found a good TRP converter yet?? As stated TRP is clever but a bit of a bummer to play, and edit?
                            There is one literally called "TRP converter", but I was not impressed with the freebie demo.
                            OZZ
                            • delaw
                              Blade
                              Pls How do I put line in Blade
