How important in an internet connection to Spiderbox's?
  • Voodoozie
    • Aug 2011
    • 7
    What does the spiderbox use the connection for, i have a terrible connection and if its downloading data all the time it just won't be practical for me.
    Cheers
    Voodoozie
  • mdt
    • 3034
    Cheers
    Voodoozie
    very important as 90% of channels that clear use the lan to recieve cw,s ect. you dont need a high speed/bandwidth connection just a reliable one. regards mdt
    • terry l
      • 92
      True m8, but you can still get quite a few channel's using patches etc..[as long as the support keep's up]..
      regard's,
      terry.
      • Voodoozie
        • Aug 2011
        • 7
        My connection isn't completely useless but it does go off from time to time for an hour or so... now does it get updates a few times a day or is it updating or what ever it does every 10 seconds.
        • jane merrison
          • Aug 2009
          • 37
          My picture on my spiderbox would scramble quite quickly if I were to lose internet connection.
          But its still the best box I have ever bought.
          My free gift subscription has expired but I still get plenty of channels clearing.
          • TheCoder
            • Jun 2011
            • 693
            New CW's needed for most encrypted channels every 8-10 seconds.
            • Voodoozie
              • Aug 2011
              • 7
              So it needs an internet connection but doesn't use as much bandwidth as say watching a internet stream?
              • setfiretorain
                • Jul 2010
                • 934
                No it doesn't, But your internet needs to stay on, within 5 seconds of your internet going off, The spiderbox would stop showing the channel, That is if the channel was encrypted!
                Regards.
                Sat Boxes
                Dreambox 500s.
                Dishes
                Sky minidish self fitted.
                • Voodoozie
                  • Aug 2011
                  • 7
                  Ok Thanks for everyone's help, it's explained everything. Just one more thing, What are CW's?
                  • satsmo
                    • 6397
                    "Control Words" needed to decrypt your video. An encrypted CW is an ECM
                    • TheCoder
                      • Jun 2011
                      • 693
                      CW's are the things that encryption systems deperately try to hide usually, as mentioned above, within entitlement control messages (ecm's)
                      All DVB based systems that are encrypted use the same base scrambling system called dvb-csa (common scrambling algorithm). It doesn't matter whether its Nagra, Seca, Conax, ViaAccess, NDS etc - they must all use this same common algorithm for the actual scrambling of data.
                      The success of csa is dependant on a rapidly changing set of scrambling keys. These keys are the codewords (CW's) and its these changing cw's that the overlying encryption system (Nagra etc) strive to deliver in a secure way.
                      As a point of interest both N1 & N3 use the very same underlying csa system. The actual streamdata is scrambled in precisely the same way now as it was under N1 - only the delivery of the codewords is different between the two systems.
                      • setfiretorain
                        • Jul 2010
                        • 934
                        Thanks for that, That helped me out and ive been in sat a year now!
                        Regards.
                        Sat Boxes
                        Dreambox 500s.
                        Dishes
