installing motorised dish. cant f-ing drill into red exterior brick wall
  • kaisar1
    • Aug 2009
    • 462
    Hi, im having trouble drilling into a brick wall. i bought a masonry 10mm drill bit, set the wired bosh drill onto hammer setting and no luck at all. 2/3 min drilling and just went in 5mm.
    i used the same drill and bit to install my tv bracket into a plaster>brick wall without a problem.
    any help would be appreciated.
  • Shady
    Shite Link King
    • Dec 2010
    • 6404
    when you installed your tv bracket, you werent going into brick, more than likely, you were going into concrete/breeze blocks, what wattage is yer drill?
      get your self an sds drill and 10mil sds bit..ps best to drill a pilot hole first with a 6mil bit less chance of shattering the brick also keeps your holes more in line
      • andy91
        • 3583
        You def drilling into brick and not a lintel?
        Try a smaller drill bit first and make sure they not from Wilkos
        Andy.
          It could be your drilling into engineering brick. That is a right ~~~~er to drill into. As Maca said your best using an SDS drill.
          • DeviousG
            • Aug 2011
            • 37
            You need a SDS hammer drill, you can hire one from hss hire
            • MrFug
              • 880
              I almost killed myself once trying to drill into brick with the bit spinning anti-clockwise. It heated up to something approaching the surface of the sun, snapped and flew past my left eye like a bullet. Doh!!
              • TEDSON
                • 45
                Was going to suggest it might be on reverse.
                Maybe the bit is just knackerd mate.
                • localhero
                  • 231
                  try putting more pressure or get someone stronger!!!!
                  • easymo3
                    • 10
                    defo sounds like engineering bricks and you need a good drill to get through them.
                    a diy home drill is no good you will need a pro drill
                    i use a bosch 24v sds cordless hammer drill and it is still an effort if the drill bit is well used
                    • kegnkiwi
                      • Sep 2009
                      • 81
                      do as deviousG says and keep our local hss hire controllers in business. Drill is everything and there's a complete different animal to normal domestic ones. Heres you can get one of these are reasonable money.
                      http://www.hss.com/index.php?g=2311#SpecificationTitle
                      I'm sure if you talk nice and sweet to a hc they will give you a nice big discount. There really nice chaps you know.
                      • Manic01
                        • 5117
                        Cheaper to buy cheap sds than hire one.
