which lnb should i use. best one.
  • pulsaruk
    • 240
    hi all i am going to install a static sat dish to go with my motorset up for 28.2e only
    i have the dish and all the stuff to set up.
    i have 2 new lnbs and want to know which one is the better one in terms of quality?
    these are the two i have:
    Genuine SKY QUAD LNB/LMB 40mm (with Mk4 BSkyB adapter) | eBay
    STARVIEW .1Db UNIVERSAL SINGLE OUTPUT SAT DISH LNB | eBay
    i will be using on a mk4 satellite dish with a starview hd combo box.
  • Manic01
    • 5117
    Is it a sky dish?
    • pulsaruk
      • 240
      yes its this one.
      [ame=http://www.amazon.co.uk/Satgear-Sky-Freesat-dish-kit/dp/B00281N538/ref=sr_1_1?ie=UTF8&qid=1314713849&sr=8-1]Satgear Sky/Freesat dish kit - New Mk4 Sky Satellite: Amazon.co.uk: Electronics[/ame]
      • andiewill
        • 490
        In my opinion and from reading a lnb is a lnb unless you go for a maasive dish ie- 120 plus then it will make a difference - ish, so i would just use the one for the dish below, i have one of those on my 90cm and it works a treat....No better than my Faval maybe better.
        ITgate TGM220 (swapable tuner), Dreambox 800 pro, Dreambox 500c x 2, DBox, Popbox media player.
        • mdt
          • 3034
          use the lnb which comes with the dish as its designed to work with that perticular dish and as long as you are in the footprint for the zone 1 then you will be fine. regards mdt
          • pulsaruk
            • 240
            nice one, thanks
