satellites.xml " merge xml trick "
  • RuberDuck
    • 1724
    iv'e been asked this time and time again how to do the so called merge xml trick so that two very close satellites can be received from the same lnb / location with no hardware modifications etc. after a good hunt around the net with absolutely no help what so ever i decided to do it my self.
    so here we go.
    included are two files, one is the original i downloaded from
    http://satellites-xml.eu/
    which includes the Tp data for both 10.0 and 9.0 east as two separate locations. i have also included my modified satellites.xml file which combines both locations into one so that you can compare both and see exactly what i did to make it work.
    NB. i used notepad+++ to open and modify these .xlm files but you can just use windows notepad if you like, although i find notepad+++ the better option and it's free as well.
  • neolxs
    • 101
    Can this be used for sky dish set up or is there nothing close enough? Thanks.
    • RuberDuck
      • 1724
      no there is nothing close enough to 28.8 east. 26.0 may be at a push if you nudge between the two but i doubt it.
