a glitch every mins every few mins
  • leicesterlee
    • Sep 2011
    • 20
    hi
    my sky hd+ gives a little glitch every so often sound cuts out a picture flicers for a split second not bad but so annoying
    brand new hdmi cable as well
    any ideas?
  • mdt
    • 3034
    Originally posted by leicesterlee
    hi
    any ideas?
    firstly check you cable and connections, if they are ok then could be a alignment issue. regards mdt
    • cactikid
      • 12017
      if it was off would the signal drop down on the scale to check or did they leave their lnb connection loose.
      • leicesterlee
        • Sep 2011
        • 20
        Its my multi room reciever my main room is fine and all cables are fine
        • wooper
          • 460
          Could be the bad weather.
          Does it do this when the sky is clear and no heavy rain??
          • cunny
            • 4915
            If 1 room is ok other is glitchy then that points towards either cabling or the box to me
            • yasminandrio
              • 1256
              hi
              any ideas?
              My mate had same problem and it was because his neighbours conifers had grow and was messing with the signal he had to get the dish moved up his wall!! Now he has wrote them a letter to cut them down!! as he dosen't get on with them!!
              Try your box from downstairs upstairs and see if its the box otherwise i dont no!!
              • leicesterlee
                • Sep 2011
                • 20
                ok thanks but been fine for years we get a bad reception due to large trees next to use anyway but had sky+ for years in my multi room with no issues apart from the reception in the summer with the leaves on the trees but only certain channels only since i put my sky+hd box in i have had this problem its not bad just so annoying
                • kennybrum
                  • Nov 2010
                  • 52
                  Ok could be 1 of 3 things 1 being the trees. Check that the connection is of at the back of your reciever unscrew the connector make sure the connector is on the cable ok this should be screwed on now connect back to the reciever and screw on hand tight not with a spanner, check this and see if it has made any difference. The 3rd thing is the LNB on the dish which is weakening the signal. If this persists phone sky up they will send an engineer out to sort the problem if they try to charge you say no you are the customer and they are not providing the service you pay for, this is not a technical problem this is a signal problem. Threaten them with cancelling your subscription they will soon send someone out to fix the proble.
                  • leicesterlee
                    • Sep 2011
                    • 20
                    i tried the cancel thing with sky and theu said ok then ill check the connection as main sky box is ok so not the trees causing it
                    • nibblitz
                      • 1300
                      Swap your HDMI's cables around with the other box, see if the problem follows the cable...
                      I had my first ever faulty HDMI cable yesterday, problem was doing my nut in as for hours I was checking everything else but the hdmi cable, it too was fairly new one.. When I finally realised I was like "well, burger me, faulty HDMI cable"
