No or bad signal
  • nasir_123
    • 30
    No or bad signal
    I have a blade 7000s all set up fine, good internet connection & speed and good signal strength. However every 2 days I seem to be getting a message saying no or bad signal which stops me from watching all the sport channels and some other channels for a few hours, whilst the asian, movie and lifestyle channels work perfectly fine. When this happens the reception bar turns red. Has this got to do with the cline server im using or is it to do with my side of things? If so how can I overcome this problem?
    Thanks.
  • Manic01
    • 5117
    Its your side.
    Check lnb connections etc.
    • nasir_123
      • 30
      I am using a sly dish which I have had for 10+ years. Also the coax cable was too short so I had to extend it using a f coupler.
      • irishbluestaffy
        • 611
        i have this prob not as often as 2 days but it does it on a few channels when others work perfect,its defo not my dish or cable as other box works perfect sv hd combo
        • andy91
          • 3583
          Definately sounds like your side.
          I would double check them connections and if the dish is 10 years old i would consider a new set up for whats its worth.
          They cheap enough off Ebay for mini dish and lnb.
          Andy.
          • nasir_123
            • 30
            Good point Andy, it doesnt cost much to get a new satellite. Which is what Ill be doing.
            @irishbluestaffy - If thats the case then It must be the c-line, but having said that it does seem to happen on every c-line ive tested.
            On a side note could anyone recommend a good c-line which includes ppv, one that does not freeze heavily (mayweather vs ortiz)
            Thanks guys!
            • andy91
              • 3583
              Thanks guys!
              Would check what your fta programs are doing when your having the issues with loss of picture,the other bit we cant say much but will pm a link to look at.
              Andy.
