bm7000s signal strength
  • duglish
    • Feb 2011
    • 87
    Installed a bm7000s yesterday on a zone 1 sky dish
    when moving the dish hit 71% on first transponder so stored the dish and done a blind scan
    however some transponders are like 45-60% but the meter stays green in the top right corner, is this ok? Would this affect any glitching? While I installed it it was fine flicking through the channels etc.
    This morning tho there has been glitching could it bethe dish? or more than likely the cs server?
  • Rodbouy
    • Jul 2010
    • 1320
    Its fine mate, Every box level of snr varies.
    For emaple the same tp on my 500 gets 94% on my 800 its gets 100%
    but on my old blade it got 82%
    • mdt
      • 3034
      different transponders have different strengths so its always best to try high/low and h/v when aligning a dish to peak the signal. 45% sq is a little low and fine tuning your dish could get a higher reading although different stb,s have different tuner calibrations also. the test will come in heavy rain! regards mdt
      • mark8393
        • 2305
        i get 98% on all sly using blade 7000. you say using zone 1, are you up north, that could be issue
        • nsw9154
          • 259
          Hello i just have a sky dish set to 28.2E ASTRA/EUROBIRD
          and i get 98% signal 72% quality but when watching a program the blue bar only just shows past a quarter can i adjust the dish signal from the menue or dose it have to be done on the dish
          thanks in advance
