Freesat lnb work with sky?
  • citygent1911
    • Jun 2009
    • 94
    Seemed like I needed a new lnb for my sky dish (using openbox s9 with cline) so I bought a quad lnb made by slx.
    I've noticed it says on the packaging that its a freesat extension kit - will this still be able to pick up all my channels on 28.e?
    Also, i've botched a dish together using a Mk3 dishwith a Mk4 lnb arm, which seems a bit shorter - could this cause problems?
    Cheers!
  • bj1
    • 445
    yes m8 lnb will be fine as for the dish arm its not the best way to do things but if the dish arm is a bit short pull the lnb out of dish arm enough to compensate the lenth untill you have enough signal...BJ1
