anybody near wakefield that can help me put a dish or know any cheap installers . the dish is new and i have a sat finder it just that i have trees were the dish is going to point but there is a gap in them but don.t know weres best to put it on the house .plus is it possible for the dish to go low on the house to get a signal from under the trees
help put my dish up with trees?
Tags: None
there about 20 foot away and about 70 foot tall . but there is alot of room to go under neath them or will that not work ? or am i just p1ss1ng in the wind and have to stick with this dreadfull kryptview boxComment
Go to w*w.dishpointer.c*m > put in your postcode > zoom in on your garden/house > select a position for your dish > select the satellite(s) you want to access > You will see a line on the map where the dish needs to point along with the elevation and direction relative to your dish. Do the same with all other satellites.Comment
as you already have the dish why not just do a temporary lash up to try it out(are you just after 28.2 or hoping to motorise)I clamp a mount in a "workmate" just to test line of site some times.if the trees are 70ft tall in theory you need to be 140 ft away with the dish at ground level.with the bottom of the dish 20ft high you would need to be 100 feet away.Comment
