Can you get Viasat signal in london, essex? got a 90cm dish? and the premier league channels?
Viasat
Same thing really, depends what receiver you have and the sat list loaded.
Packages: Viasat - KingOfSatComment
viasat
Yes i cant seem to pick viasat pl channels can get others like viasat history but not the pl channels on 90cm dish Liverpool would love them channels for the footyComment
Check your set up you should pick up the PL Extra channels with a 90 cm dish, this transporter is quite easy to get decent signal, I have set up a few 90cm dishes on the Wirral, I use a 85cm Fracarro dish myself without problem. You will not pick up the Viasat PL HD channel up in Liverpool unless you use a 1.1 dish as this is a different transponder and does require a large dish and a high gain LNB, to be honest unless you have a Viasat viewing card then this would not matter as this channel can't be shared as yet.Comment
Thanks blue boy thought it could be shared ? willCheck your set up you should pick up the PL Extra channels with a 90 cm dish, this transporter is quite easy to get decent signal, I have set up a few 90cm dishes on the Wirral, I use a 85cm Fracarro dish myself without problem. You will not pick up the Viasat PL HD channel up in Liverpool unless you use a 1.1 dish as this is a different transponder and does require a large dish and a high gain LNB, to be honest unless you have a Viasat viewing card then this would not matter as this channel can't be shared as yet.
Have a look at my set up if you can pick them up in the wirral
My dish must be out .Comment
