this is driveing me crackers theres a option to use usb to upload your cccam server settings other boxers i just copy paste to cccam and upload to box .for some reason the orton boxs not haveing it what am i doing wrong do i hve to set the cccam notepad lay out another way..thank you for any help..
ORTON-HD-X403P help how to
was refering to gmb45's little note, not yours
sure if you google openbox S9 or search within the forum you will find what you are looking for. Also if members see you are actually trying to find the answer to your question, rather than being spoon fed the answer you are more likely to get posts relevant on your thread.Comment
well charming.to help all others who have a orton hd. boys and girls it is best to enter everything manually as i didnt find a soloution so enter manualy all the best with your boxes .was refering to gmb45's little note, not yours
Follow the guide you may have got when you got the box
or download
"Howto connect to the server in Opticum X403p (1).pdf"
get a usb file & make a file named
hsdata.cfg
its what the box wants instead of a instead of a cccam.cfg file
now where youd normally have a
c: bobsserver.ath.dx 40001 fjishV HoW7fTE
you would take out the first C:
replace it with cccamd
and replace any SPACES with SQUIGGLES ~
so you would now have
cccamd~bobsserver.ath.dx~40001~fjishV~HoW7fTE
save file on drive NOT in a folder
put in box
go on network settings
then push the look button (its got a magnifying glass on)
and itll import data
reboot box
and its workingComment
