1.8m satellite dish help
  • djskutz
    • 16
    hi everyone, i currently have a 1.1m dish running on a technomate diseq motor, im on the verge of buying a 1.8m and wondering would my motor handle it, the dish weighs about 6-7kgs max(i think) now the motor says it can drive up to a 1.4m or 20kgs max, my question is why cant i use this motor then?? Please can someone with very good exp give me good advice or has anyone ever tried this?
  • cleanrite
    • Mar 2010
    • 62
    I personally wouldnt try it,the motor might be able to turn it,but as soon as we have any stong winds,it would rip your motor to shreds,the wind resistance on a 1.8 meter dish would be incredible.
    use an actuator,It will be expensive to fit but would e better in the long term
    • djskutz
      • 16
      is there no way it can be kept steady by giving it extra support?
      • MrFug
        • 880
        Are you planning on having this bolted to a wall?
        • dick b
          • Jun 2009
          • 2462
          like the others I wouldnt entertain a dish of that size on a diseqc motor you need a 36Volt actuator.what sat/channels are you after?and as asked how are you mounting it,a ground mount is the best way with larger dishes.Its doubtful you will find a 1.8 dish that would fit a technomate diseqc motor anyway.
          • adam123
            • 8
            motor
            hi m8
            get this motor work very well but bit noisy but its worth it
            is Jaeger 1224 H2H motor
            • mdt
              • 3034
              i know a guy who has a 1.8m spun ali dish on a 3 inch pole with 3 very strong k brackets mounted on his house wall but it was installed by professionals and uses a polar mount/jack combo. i wouldnt go above 1.2m with a diseqc motor as heavy winds will rip the entire thing off the wall! if you have to have a 1.8m dish then get it professionally supplied/installed. it will cost a arm and a leg but will give you peace of mind. regards mdt
              • djskutz
                • 16
                yeh thanks for all the info lads, im in the midlands of ireland and want to pick up the nordic beam on 4.8e, my head is totally wrecked and dont know of people in ireland who install a dish this big
