Blade Media 700s DISEQC Settings
  • dadon123
    • 34
    Hi all
    I just need a bit of advice off you guys. I have 2 seperate dishes, one pointing 28.2e and the other facing 13e (both with universal LNB's) connected to a blade media 7000s. I currently use a manual A/B switch to switch between both dishes when needed. But i would now like that to happen automatically. I would like to know which Diseqc switch i would require (diseqc 1.0, 1.1, 1.2, 2.0?) and also which options i should select in the blade dish setup menu when setting up the switch.
    Thanks in advance
